1 - 16 of 16 Posts
SO here is the deal I drove my truck two days ago back and forth to wenatchee which is a total of about 2 1/2 hours of driving and ran fine. SO i hopped in it yesterday to go and cranked over good and rpm gauge is moving, checked fuses all good, just replaces CPS with motorcraft one. It cranks good, no smoke, checked the HPOP reservoir topped it off with oil. Wait to start light comes on. I dont know what the hell is wrong with this stupid thing! it doesnt even try to fire. Any ideas? :dunno: Thanks
Discussion Starter #2
No ideas at all!!!!????!!!!?!?! :doh:
glow plugs, just a guess though
ROLL TIDE ROLL !!!!!!!
I would make sure your getting fuel. No smoke and doesn't try to fire sounds like a fuel problem.
IDM may have went TU... not sending a signal to the injectors to fire. Look for shorted wires near the IDM, or swap it with a known good one if you can.
2.5 hours to Wenatchee and back... are you in the Methow Valley?
Will have to check that! I live in Moses Lake, So i'm pretty sure its not glow plugs because it has been in 100s here lately. I know it have to be something that is controlling the fuel.
See if the fuel bowl is full,and the heater in the bowl has not shorted out,this will blow a fuse in the panel (under the hood) and cause a no start.If the bowl is empty i would suspect the lift pump.
if there's no smoke then the injectors are not firing or else there's no fuel pressure. My bet is that its a high pressure oil problem, i would find a way to moniter the high pressure oil and see what its doing. If its not building 500+ psi while cranking there's your problem, causes would be dirty IPR, IPR o rings or injector O rings.
OK I'm going to give you the update, to start this off now my car has quit me too so i need to get something running STAT!!!!! There is fuel in the fuel bowl it is full, there are no blow fuses checked under the hood and under the dash fuse panels. The Hpop didnt have much fuel in it but it could have been from me cranking on it before i checked it, I filled up the Hpop still no fire, checked again topped it off, still no fire or smoke? I just had some stage 1s put in about 2 months ago maybe more (and the truck had been running excellent) very smooth, no white smoke. SO i dont think it would be the injector o rings. IF the ipr was dirty wouldnt this be a problem that started and would kind of work its way to not running? Remember it ran perfect than i parked it for couple days then wouldnt start!!!??!!
Please tell me you put oil in the HPOP reservoir and not fuel...
All fuses good and still no start... try unplugging the ICP sensor (front of drivers side head) and see what that does. Did you check for wiring problems at the IDM or at the valve covers?
you really need a way to run diagnostics, check pressures, etc... we can tell you things all day long but if you dont have any way to get us real feedback then all we are doing is pissing in the wind.
Discussion Starter #14
I did put oil in the hpop :wink[3]: I will unplug the icp and see what that does. I checked the wiring and couldnt find anything that looked trouble sum. :dunno:
Discussion Starter #15
Ya i dont have any means of doing that, I am located in Moses Lake, WA if you are near by and want to give me a hand :thumb:
1 - 16 of 16 Posts
