This is my 1st post, so here it goes.
I've been working on my 2003 E350 7.3L for the past few months now on and off. I bought it back in February. When I first got it, it didn't take long to notice that the guy that had it before didn't really take care of it. I noticed it had a diesel/oil leak. Found that the engine valley was full of oil and diesel, could see that the filter/separator was leaking pretty bad. Also found out that the glow plugs weren't working. So I decided it was time to fix it right. I did a ton of research to see what else I might need while replacing the glow plugs and rebuilding the filter/separator. Found a bunch of the info on this site.
It was running "OK" before starting the repair upgrade process. Since the previous owner didn't take care of the vehicle I decided to replace some other items that were recommended to replace on other threads while I had it apart.
So this is what I did:
-Replaced glow plugs, UVC harnesses, engine wire harness to VC pigtails, VC gasket, and GP relay
-Replaced most of the sensors and their plugs to wiring harness- CPS, low pressure oil temp and pressure sensors, ICP and plug
-Replaced LPOP (Melling) and harmonic balancer
-Replaced water pump, tensioner, and belt
-Replaced HPOP (Bosch), lines, head to HPOP line fittings, and IPR and plug
-Rebuilt turbo, new cartridge, upgraded wheel, non-ebpv pedestal. ebpv delete plug
-New Diamond eye 4" exhaust, new bellowed up-pipes
-Upgrades- fuel rail crossover, high pressure crossover, High Flow Fuel CVD Fitting, air intake delete plug and code eliminator, billet intake plenums, ccv mod, high flow banjo bolts
-Changed oil
Most of the parts are from Riffraff diesel, Clay has been awesome through all of this. Pretty much all the parts are OEM (Ford or International) unless noted.
Tried to start- Crank No Start
HPOP reservoir full, fuel pressure 60-65psi (mechanical gauge), battery voltage good, engine RPM over 150.
Then cranked engine a bunch of times with AE connected to vehicle. ICP pressure only reaching 280-300 psi.
Dead headed HPOP-easily reached 1500-2000 psi while cranking
Isolated drivers side head and checked pressure- only reached 280-300 psi while cranking.
I then replaced the injector o-rings, evacuated the cylinders, and connected everything back up and tried to start- while cranking only getting up to 280-300psi. After a few times trying to start the started bogged down and died.
After replacing the starter, I decided to make sure that the cylinders were completely cleared out. So I removed the glow plugs and cranked the engine a few short times with the VC wiring disconnected. Replaced the glow plugs. I then check the ICP while cranking- it was able to get up to 1200psi pretty easily with both heads disconnected from the engine wiring harness. When I plugged up one side it would only get to about 400-420psi. With both heads connected only got to 280-300psi. I also checked the ICP and IPR for continuity to the ECM, both checked out fine.
I then remembered that the ICP was an aftermarket so I ran down to ford and grabbed a OEM replacement. When I replaced the sensor, I noticed that the oil rail wasn't completely full (air still caught in it). I screwed the sensor in slightly to let the air out while I cranked if over a few short time until oil came out. I also did this on the passenger side front plug, directly across from the ICP sensor. So I guess most of the air should now be of the rails now.
After that I got pressures of about 320-380psi while cranking. Once in awhile would peak at 400 psi.
Seeing that I was getting plenty of pressure when the VC harness was disconnected I figured it was an electrical issue maybe telling the injectors to open slightly. I checked the continuity from the IDM to the VC plug, each one read less than 1 ohm. I removed the IDM to check inside for corrosion, inside looks spotless.
Plugged everything back up. Ran KOEO test and buzz test. Everything passed.
I'm going to check all the wires again tomorrow to see if they ohm out and none of them are grounded. Then make a wiring harness to check what kind of signal the injectors are getting with the key on. I'm guessing at this point it could be the IDM. Not sure though.
I can't really think of anything else to do now.
Sorry for being so long winded. Thanks for any light that you can shed on this.
lease: Help
-Changed oil
