2006 6.0 Brand new warren diesel long block installed, crank without proper tunes for 30 seconds to check for obvious leaks, wouldn't start again even after flashing the proper tunes. Motor would build 300 ICP psi but No start. Ended up being a bad low oil pressure regulator in the front cover. Replaced that, drove it for 500-600 miles and just as I'm about to change the oil for the first time it does the same thing. This time though my dash flashed low oil pressure after starting then it would die. (This is after driving it for over an hour) Did this twice then went straight to crank no start mode. Pulled the regulator back out and there was no obvious trash or wear that I could see. Read on here that it could be as simple as an oil pressure switch on the top of the oil cooler. Replaced that and the pigtail leading to it as it was showing bare wire. Still after all of that, crank no start. Please someone make it make sense. I am BEYOND upside down into this POS and I just need it to run for once.
My guesses are bad LP oil pump, another failed regulator or a wiring issue I'll never find. Truck ran like a top, until it didn't. Please let me know any ideas.
