1 - 2 of 2 Posts
Have any of you high boost guys experienced any oil leaks at WOT? I have a truck in the shop right now that has elite turbos, full fuel system, injectors, rails the whole nine yards, and am starting to think that the crankcase ventilation system is inadequate on the passenger side of the motor. When I go WOT with this truck it develops an oil leak at the pass. side valve cover either at the glow plug harnesses or the valve cover gasket. I have already replaced the glow plug harness. The valve cover gasket seems fine. Just looking for a little insight before I take the valve cover off and weld a fitting onto it and T it into the inlet system (torque tube). Thanks for the help guys!!!
Interesting! :popcorn2:
1 - 2 of 2 Posts
