1 - 2 of 2 Posts
I need to replace the (I think) vacuum hose that connects from the top of the wheel well to the axle, both sides, i believe this is for the auto locking hubs? What type of hose can I use for this?
Also, something that just showed up today, the parking brake light is very intermittent on coming on, it doesn't more times then not now. What do i need to check? Is there just some switch on the pedal itself? It had been working fine till what i can remember, today.
Powerstroke Junkie
The vacuumm hose for the hubs is just reg old vacuum hose nothing special. For the parking brake, could be a loose connection on the bulb, or check the switch at the top of the parking brake assembly, there is a connection there that could be loose, it is a grey wire IIRC?
NCH
1 - 2 of 2 Posts
