1 - 2 of 2 Posts
Hey guys the other day i was on my to the race track and started to notice the temp on my truck began coming up, after purchasing my pit pass i look on my insight and noticed the temp running at 220 and climbing, i then put the truck in neutral and slowly brought the the rpms up a little to help cool, then all of the sudden the temp came down pretty quick back to around 192 do yall think this is a tell tell sign the thermostat is going or the egr cooler, when i got to work i pop open the hood and noticed the coolant resvoir was bone dry, i added a gallon to it took every bit of it i need to go get more. Any comments?
shhhhh, can you hear it?
normally id say its the thermostat but with it being a 6.0 i would check your exhaust pipe and oil first to make sure you havent lost a gasket.especially since you lost a gallon of coolant.
1 - 2 of 2 Posts
