With this cooler weather coming, my truck has started to show the return of poor cold running. The truck starts just fine, but the idle will definitely have a lope to it. If I don't let the truck warm up for at least 5 minutes, there is a definite miss heard when driving down the road. It also shakes badly. Once it warms up, it's fine and has great power (albeit, I have noticed the MPG down a bit lately - even when babying it).
I'm leaning towards a bad injector. I've tested FICM, made sure that all fluids and filters are changed, and I ALWAYS run Stanadyne with every tank (and have for the last 20,000 miles). I do have a SES and it shows either a bad #2 glow plug or circuit. I do plan on changing the glow plugs along with the circuit wiring on both sides, but I don't think that's going to fix my problem.
Short of taking the truck to the dealer and getting raped for $100 for a diagnostic check, is there any other method a DIY owner can test for a bad fuel injector? I'm prepared to replace any that are bad, but would really like to find out which ones for less than Ford's diagnostic fee.
-Brian
-Brian
