Just finished my stud job everything went well...only problem im having is my coolant temp on my dash isn't moving and my edge is reading about 140 to 150 at idle and and 110 to 120 while driving...im leaning toward thermostat being stuck open but wondering if anyone else has had this problem
The Silent Service
Even if the theromostat was failing, you'd be seeing around 180* while at operating temp.
Not ruling out the t-stat, which I would recommend replacing during this anyway, but you will want to check the sensor itself, and its wiring harness.
Where is the sensor located?
