1 - 12 of 12 Posts
So my question is when I drained my degauss bottle when I installed my ipr coolant system I filled it back up with a gallon of the Ford gold coolant. Should I have diluted it? My current temps are ect 176 and eot 188 is that normal? Should I drain some coolant and add half gallon or so of distilled water?
it wouldnt make your engine extra cold.... sounds like a thermostat issue to me
If it were 50/50 before draining the degas bottle, then adding 1 gallon of concentrate back is only 1/2 a gallon more charge - it would take you to a 52% solution (you are fine with up to a 60% mix).
As to the temps - are you sure the ECT is correct? Does it read the same as the EOT when the engine has sat overnight (before starting up)?
The Ford thermostat usually fails wide open, so my vote is also for a bad thermostat.
Sent from my Autoguide iPad app
You don't wanna change the t-stat do you?
Discussion Starter · #9 ·
Haha nope, looks like I'm going to have to when I get home from North Dakota in a couple weeks. Cause its back at 176, oh well can't be that hard.
Discussion Starter · #10 ·
Anybody happen to have the part number off the top of there head? Guess I'll just order it while I'm at the rig.
1 - 12 of 12 Posts
