I have a few questions before I spend some money on my truck.
My EGR cooler and Oil cooler are starting to go out, also when its cold outside and I start my truck I get two injector codes sometimes and some times cylinder contribution faults.
1. I am getting ready to order an EGR delete and oil cooler kit from RCD. Before I do this I thought I would check my coolant system pressure, and driving, the pressure ranges from 7 to about 11 PSI...If I really gouge it I can get it to 12 PSI...from what I have read this a little bit on the high side...But could a failing EGR cooler and Oil cooler cause my pressure to be higher than normal? Or is there a good chance my HG's are going too?
2. I am assuming the cylinder contribution faults when it is cold outside could be due to the injector problems, is this correct?
3. Should I just replace the two injectors that have thrown codes? I tried the rev-X additive already...
4. Is there anything else I should do, while I am replacing the two injectors and the EGR Delete and new Oil Cooler?
My truck has 160,00 mostly highway miles, and had new HGs, oil cooler, and egr cooler installed by dealer at about 40,000 miles.
Any advice will be very greatly appreciated...I can't really afford to pay to have the work done, so I will be doing it all myself with the help of a mechanically inclined friend of mine.
Thanks,
Tim
Thanks,
Tim
