1 - 20 of 28 Posts
Old min is new Max and all.....when upto operating temp....there's very little in the bottle...
This sound normal?
Sent from my Motorola Electrify using AutoGuide.Com Free App
Apparently, me and 41 other people aren't sure about this either....i'll have to check mine, next time I fire it up.
Mine does the exact same thing. It also sits that way until I remove the cap no matter how many days it sits without being run. Dont know if that's good or bad...
Next thing is to figure out why my ect won't get over 190* with a new tstat?
Probably a faulty temp sensor.
I guess I should've worded that better...it will get over 190*....but settles at 188-190* in most cases...even in temps 100* or so
hmm u may have a faulty sensor.. My truck just got a new motorcraft stat and my temps stay at 190 all the time no matter what temp or load.. I was surprised
My coolant stays at the min. mark when its cold and when at full operating temp. This is the first of heard of the coolant not being in the degass bottle when warm.. hmmm
War is the answer!
My coolant level does this too but I think I might have bad head gaskets. Does your truck puke coolant?
Sent from my GSIII on the Blazer ROM LF8 Radio.
War is the answer!
Well if your not losing coolant I wouldn't worry too much about it. So as long as when you take the cap off the level always returns to the min mark your probably ok.
Sent from my SPH-L710 using AutoGuide.Com Free App
mine is the opposite. i have mine filled to the line on the degas when cold. when i drive and get up to temp it is above the line, when it sits overnight it settles back down to the line. i push no coolant out of the bottle nor do i lose any.
i thought when the engine got warm the coolant expanded and went up in the degas not down. maybe something is wrong with mine?
Your cap may not be holding pressure.
My truck does the same.
Sent from my DROID Pro using AutoGuide.Com Free App
When i unscrew it when its warm it releases a bunch of pressure so i assume its holding, how much im not sure
Yea, I would say so. Interesting.
Yours is normal.
The liquid expands as it heats up.
Air pockets (or gas pockets - which is not normal) can cause erratic and sometimes opposite behaviour w/ the levels.
Discussion Starter #19
Yours is normal.
So you're saying my situation of having lower coolant when warm vs cold is not normal?
1 - 20 of 28 Posts
