1 - 2 of 2 Posts
I have an 08 6.4 power stroke, the motor has under 200k km on it (like 120k miles) and i have a coolant leak as you can see in the pics i attached. Im wondering if its the water pump weeping, although before i rip out the fan to try and get a look at the weep hole i just though id ask if anyone has any other suggestions as to what it could be. Its leaking in the front of the motor somewhere and looks like it is coming down between that cover in the centre possibly (not sure what its called). Anyways if anyone has any suggestions or pointer sends them my way!
I was reading through on the 6.4 discussion page and saw this. Not sure if u found ur problem or not, but if u haven’t here r some tips. Check your front timing cover. Just had to spend 3800 for a timing cover, radiator, water pump, thermostats, fan clutch, low pressure oil pump. The cover had a pin hole from tap water and the wrong anti freeze causing water to get in the oil.
Only put distilled water and ford anti freeze in it
Hope this helps
1 - 2 of 2 Posts
