I have coolant leaking from the passenger side got a picture not the best but it's as good as I can get. The coolant is coming out from the circles area where it looks like the 2 surfaces are mated green dot for where the leak is. Is this a gasket that can be replaced or is the head toast? Any help would be appreciated.
Discussion Starter #2
Bump......anyone?
That's a hard one to diagnose and say one way or the other. 6.0 issues always seem to lean toward head gasket failures, especially with the stock head bolts. I'm chasing a coolant leak too and I've done the studs and everything. Good luck, as long as it's leaking out and not into the oil or cylinder I'd run it!!
