Hey guys, i have an 04 that is bulletproofed. There is a coolant leak that has to be coming from either the radiator or the water pump im assuming. i replaced the t-stat this summer and it is dry, as well as the degas bottle. It doesnt start to leak until after the truck has been sitting for 3+ hours.
Check your radiator hose neck isn't cracked or the top tank. Someone may have put too much weight on it.
Water pump would show up further back on the engine.
Thanks that is what i concluded!
