1 - 17 of 17 Posts
i am debating buying the kit from dieselsite or making my own i plan on flushing and changing my coolant and want to put it on when i do this so i wanna do it soon (before winter) if i were to make it how would i go about doing this i have heard that you can get the stuff from napa
if i were to get the stuff and make my own kit
how much would it cost vs buying the kit
if i make my own where should i mount it on the frame rail or engine compartment or where i do work on a farm and drive off road so it does need some sort of protection i dont want it to get ripped off or poked
any advice would be great thanks brett
Powerstroke Junkie
I bought the kit from Dieselsite when it was $60, for that I couldn't make it myself. Only you can say if it is worth it to you, I won't give the parts list or the how to plumb it because I wouldn't want someone doing that for my CCV Mod kit, sold through Stealth. But I will say that every PSD should run a coolant filter kit!! Changing it one time and cutting open the old filter will make you swear by them!!
NCH
Shaking the Bush Boss
I pieced mine together....had a good parts supplier;)... If I ever buy another truck..I'll just order a kit
its just easier to order the kit. i priced all the stuff on how to do it and it would have been cheaper and quicker to just order the kit.
I am going to order the kit sooner or later, I noticed in their ad on dieselsite the said the mount bracket isn't aluminum more, now all it says is "black powder coat". So is it powder coated alum or steel?
ok thanks guys i guess ill be buyin the kit
thanks guys i check today i can get a filter base and a couple of the fittings from carquest for like $45 and a filter with sca for $10 if i run regular heater hose i should be able to get that for about $10 so i will have maybe $60 into it the only thing im trying to decide is where i want to mount it do i wanna put it on the frame rail or in the engine bay im thinking engine bay would be better seeing that i do drive off road and dont want it to get damaged but also seems it would be alot easier to mount off the frame rail the other question i have is i know the inlet would come out of the tstat housing but where do i want to route the retun to the overflow bottle? thanks for all the help guys as tubular stated i would like to do it myself to save some cash (im in college) and i like the expirence of building things myself
you dont want the SCA filter. just get the standard filter
Discussion Starter #13
why dont i want the one with sca
Powerstroke Junkie
You don't want the SCA filter as that isn't the proper way to maintain your SCA level. You want to test with test strips and add as needed, or use a quality coolant like Fleetrite and you never have to add SCA's again. If you look just behind the front tire on the drivers side there is a small cubby hole where the filter fits perfect and it is away from anything that can harm it. I don't like it in the engine bay, looks out of place and just gets in the way!!!
NCH
Discussion Starter #16
thats fine bc there cheaper than the sca filters but i have 1 question what would the diff be between pouring it in from a bottle when it needs it or throwing on a sca filter when it needs sca's
You would be able to get the exact amount you need if you test the coolant and dump some in. With the filter you wouldn't quite know how much your putting in.
1 - 17 of 17 Posts
