Ok I am confused I check coolant cold and its just below Min (on the Max side of recall sticker)...Then when I start it it drops considerably instantly... After it gets hot the coolant re appears about 1" below min... As soon as I shut it off coolant refills degass right to where its supposed to be 1/2 inch below min...
Question is why does the coolant almost disappear when I first start it then levels off... Any thought
Thank you
Thank you
