1 - 20 of 20 Posts
I have a compressor wheel off of a stock 03 7.3 turbo, will it fit into my stock 97 turbo...?
Its in much better shape than mine...
Thanks,
Nic
Don't think it will. Maybe a tech on here can tell you more.
duct tape & zip ties
Just order the WW wheel from one of the vendors. It is the same wheel as your stock 97 wheel. But the stock wheel off your 2003 7.3L should fit the 97.
well, he put in a wicked wheel, and its not the same as mine, and i got this one for free... and im gonna use it if it fits.
The wicked wheel is not the same as your 97 oem wheel.
Discussion Starter · #13 ·
Havent seen mine in a while... way back when I put the intake on I noticed it was kinda beat up, but I dont remember it looking like the WW...
and asking about the 03 wheel... pros cons, is it the same as mine?
Ok well when I replaced my oem wheel from my 2002 with the ww. The ww has every other vane half the size of the other vanes.
On my stock wheel all the vanes were the same size.
Yep that is what a damaged ww looks like. I say if you have a stock 03 wheel go ahead and run it. It will be better then what you got now. But if you want to replace it with a stock one just order a ww from one of the vendors.
1 - 20 of 20 Posts
