Where would you hide that and all the relays behind the dash though? These are mainly just for switches, but then there's the inverter, amp, cb radio, gauges, switches, aux outputs hidden behind dash, extra lighting in cab and on bottom of doors.
That's just for the inside, outside going to have 4 fogs extra driving lamps, back up lights, compressor, train horn, water meth kit, slip tank with transfer flo pump and pump on top, cab lights, power amp folding steps.
Just like so much stuff and I don't really want to be tapping into factory harnesses other then to turn on the fuse block.
http://painlessperformance.shptron....dium=email&utm_campaign=ShipmentTrackingEmail
I bought 3 of these but want to have everything on switches so I can turn almost everything on and off except for things needed to start, and I don't want to be draining my battery while it's off, I was wondering if there would be a way to make those circuits into 7 ignition hot sources instead of 4 and 3
