1 - 20 of 29 Posts
Just wandering what ppl have seen. I know here in pa we had record lows with windchill to -20. Actual temp was depending on place 0-3 in the morning. I tried to start it and my truck said no haha. Plugged in for 21/2 hours later started. So lets hear about some cold starts
I think you might have issue's. Your 6.0 should laugh off those temps. Have you checked the health of your ficm? What are you using for oil? Hows your batt's?
mine started actual temp -11 all i did was cycle the glow plugs twice fired up in about 2.5 seconds. growled for 2 seconds and evened out.
Mine used to hate to start. Found my ficm was at about 30 v cold . Got a swamps upgrade and she fires right up with out cycling the glow plugs. Now at home I always plug in below 40* or so but she sits for 12+ hrs at work. I have had no issues hitting the remote start in these very low single digits and the truck firing. Little rough at first but clears up within 3-5 seconds.
Video of my cold start this morning at -8*F. Unplugged all night. As a matter of fact this truck is never plugged in. Smoothed out after 30 seconds and went into high idle.
You should check battery health, FICM...what weight oil are you running?
I just did a oil change yesterday 15-40 motorcraft is my oil, it started fine the day before at 9 degrees started right up. It sat at work for about 4 hours just went to start it and fired right up.
I honestly didn't think it was bad. Just put the block heater on a it started. I had my batteries checked in Aug before I got my new alt.
Mine has only been plugged in twice to see if the heater actually worked. has never let me down, coldest ever had to start was -10 wind chill -40.
Discussion Starter #12
So should I be looming at my truck for something wrong?
OP... What part of PA you from? I'm down in Washington County.
I haven't had trouble getting her started... But I have been sidelined by a gelling issue.
Discussion Starter #16
I'm from Lancaster county
Mine was plugged in all night last night -16 with wind chill at -40 in Wisconsin and truck fired right up.
Truck sat for about 36 hrs stone cold no plug in and 2 degree oil temp use my remote start so single cycle snd she fired right up. Not happy but only turned about 3 sec and she was purrrring! Coldest Maryland gas seen in a long long time!
Discussion Starter #19
So most of the 6.0 start up in temps even in the negative? Does anyone think I have a problem? If so where should I be looking?
Discussion Starter #20
The truck runs great. Plenty of power first time it didn't wanna start, and like I said plenty of cold starts. It's currently 11 degrees and fired right up.
1 - 20 of 29 Posts
