1 - 13 of 13 Posts
My truck has recently developed a problem starting when left to sit for a day or so, I have been leaving the block heater plugged in and it starts fine, but am afraid to do any camping with the camper we just bought. New Hpop, ICP, IPR, and both CPS's. It does puff out a bit of white smoke when it starts, but it has pretty much done that since day one. 04, 170K mi. Thanks for any help.
Check your glow plug system. Run a compression test on your cylinders. Any codes?
Check your FICM.
Load test batteries, check ficm.
sorry for the late response, ive been working. i will check the ficm voltage. i think there is a post on here explaining the proper procedure i noticed it wont buzz the injectors unless it is up to near operating temp. it will start fine after its been running. The FICM is about the only thing I havent replaced on this truck. Any suggestions on who does the best rebuild or new unit? Upgrades? Thanks again for all of the help you all have given me on this money pit over the years.
Dannyboy my buddy is gonna bring his AutoEnginuity setup home from work to pull codes next week and I will let you know what we find out. Thanks for the reply.
Ficmrepair.com
Finally got around to testing ficm voltage. 47.6 KOEO. 15.3 while cranking. Im sending it to ficmrepair.com and will post the results. Thanks
What do your batteries do when load tested individually?
Discussion Starter #11
The batteries load tested fine. Alternator seemed like it could be doin better under load, but the batteries are twelve plus before cranking.
Discussion Starter #13
got the FICM back frrom ficmrepair.com added the Atlas 40 tune. Installed tonight and the truck cranked over twice and fired right up. It wasnt plugged in since I sent the FICM out for repair. Back to runnin like a champ. Thanks to all for the help and ficmrepair.com for the great service.
1 - 13 of 13 Posts
