3 grand is a bit more than id wanna spend. Does the 05 axle bolt right up? and if i were to do this, what about lifting it? just get a lift for an 05 up?fabtech and skyjacker both make kits... price starts at 3kplus for the conversion....
i have also seen people grab a 05+ newer front axle with all the susp parts.... its fairly easy to do the install
well you would need all the brackets. best thing to do is just take the whole front end. not sure how much that would cost but by the time you get everything you might be at the same cost than what it would be to get a kit.... oh the kits come with either a 6" lift or 8" lift... so its not just a conversion3 grand is a bit more than id wanna spend. Does the 05 axle bolt right up? and if i were to do this, what about lifting it? just get a lift for an 05 up?
