1 - 14 of 14 Posts
Has anyone converted an 05 (or earlier I guess) Excursion over to the 05+ coil spring front suspension that the 05+ Superduties came with? I assume you would need to pick up some 05+ axles as well as the other suspension parts. Was just curious how hard it would be. Cause a nice clean 4-linked Excusrion with a Cummins Diesel Conversion sure would be nice.
Discussion Starter #2
I have a set of '09 axles that I will be putting on my '04 Ex using a combo of parts..My modded rear B codes and front 4.5" Icon coils with Pure performance's 4 links..Don't know if I will reuse my #7100RR's in front or not.
Cary
Sweet, my wheels have been turning lately. That usually gets expensive LOL
KING of BLING!
It wouldn't be any different than converting a 99-04 sd. About the only difference is the gas tank and rear driveshaft.
Things that may you say hhhmmmmmmmm!!!
Vendor
Great news, you thinking is bound to get somebody in trouble! We have plans to build a bolt on 4-link kit using the stock 99-04 axles and 05-10 coils (meaning you could use anyones set of coils including stock). Its a bit out, as Im trying to get a decent inventory built up to get my turn around times down. Aswell as a new building so I can do my own powdercoating, tired of the flaky local companies that couldnt give two sheets about deadlines!
Sweet!!! Glad to hear the news about powdercoat!!!
Yeah dude, that would be pretty damn sweet. You got a project we should know about??
If I could find a clean, single color Excursion (cant stand two tones), with a V10 or a blown motor, I would really think hard about putting the truck back to stock, selling it and swapping everything over to the Excursion. Along with the Cummins swap of course!!
Discussion Starter #11
I rather do 05+ axles. Wider and bigger brakes.
I hope that comes out soon and at a decent price. Been wanting a coil setup, but didn't want to part with my Dynatrac or SSBC parts.
I believe that full traction makes a kit that does that already. I've seen it on a few trucks out there. Pretty sweet kit actually.
It's a 4 link with 4.5-8 in of lift. I would love to go that route, but I'm not gonna get away with much more than a leveling kit at the moment. A basically stock 05 setup with slightly longer coils would be almost perfect.
1 - 14 of 14 Posts
