I have a2005 350 I am almost positive it had a coil Leveling kit on it when I bought the truck but I changed the rims and tires from a 315 75 17 to a 325 50 22 and now they rub a little bit and I was wondering thoughts on adding a 2inch coil spacer on too of the leveling sprngs
Do it , I've had my 2.5" leveling kit on the front since truck was new
Your post is not very clear. You already have a leveling kit of one form? and you want to add another 2 inch block kit to the front end as well?
4+ inches? No way would I do that without dropping the control arms and dropping the track bar. Your caster would be complely forked up.
I think it has a leveling kit on it the guy I bought it from said he didn't put one on it but he was the second owner how can I tell if they are the factory could or not
Got any full size pictures of the truck? Just going by what you have posted it sounds like you would be a good candidate for a 4 inch lift kit. The systems that use the stock radius rods can be had fairly cheaply compared to some lift kits.
Either that or leave the lift alone and get some wheel spacers
