1 - 16 of 16 Posts
P0715 Input Turbine Speed Sensor Circuit Error
P0717 Input Turbine Speed Sensor Circuit No Signal
What is this?
sounds like a fault in a sensor on the turbo.
Yeah thats what I thought....that sucks....gonna have to set it back to stock put the DPF back on and take it in I suppose.
CODES
Its the transmission turbine input shaft. Not the turbo.
Insufficient input from TSS Sensor. PCM detected a loss of TSS signal during operation.
Discussion Starter · #7 ·
What does that mean?
Transmission slipping?
CODES
Or could be that the difference in the turbine shaft sensor compared to the output shaft sensor is not what the PCM expected?
CODES
Tranny slip is a possibility. But don't expect the worst right off the bat. Do the things that cost nothing like check the fluid level, temp. and condition of the fluid.
Discussion Starter · #10 ·
I am told its the speed sensor.......must be thrown off form the larger tires?
i've had my big tires on for 8k miles and no codes
Discussion Starter · #12 ·
Great for you...I have mine on for about 4K miles.....pretty much the entire life of the truck, and mine threw these codes...and its the speed sensor....the sensor is ok, so its not a bad sensor...
i was stating, for others to read. that i dont think big tires are always going to cause this.
Could it be related to the tune?
Discussion Starter · #15 ·
Oh I hear you...I dont think it is cause of the tires....I was more asking could it be.
Discussion Starter · #16 ·
1 - 16 of 16 Posts
