I have 3 trouble codes according to my Edge p0264,p0266,p0405.
It is running rough and smoking white from the exaust .I here that is normal after a blown oil cooler repair . Where should I start to fix these codes .
Thanks, Shane
p0405 is an egr recirculation code, did you recently do an egr delete? that would make it throw that code.
p0264 and p0266 are cylinder # 2 codes it could be a bad injector ( which could be your white smoke) or it could be the FICM. have you checked your FICMs voltage? if it is good, I would clear the codes and see if it comes back. if it does I would suspect #2 injector needs replacing.
thanks for the reply. After going over my work looks like I unpluged the #2 injector when putting the air filter piping ot turbo. I lost one the clips that hold the plug in place. I will have to find a new one.
The only code I have now is the EGR which was removed so that makes sense.
All is good in my 6.0 world.........Hope it stays that way
good deal, glad to hear you found the problem. you can get a tuner to shut off the cel if it bothers you.
