1 - 2 of 2 Posts
Hello I have a 2004 Powerstroke and I have change glow plug number 8 two or three times and I am still getting this code popping up on my tuner is it okay? Should I worry about it? How do I get rid of it from stop popping up on my tuner and how can I fix it? Also I have a new wiring harness when I did my head studs
Sent from my SM-S767VL using Tapatalk
Double check the gpcm plug. The little sealing ring can slip out of place and cause these problems. If that isn't the case, then you probably need a new glow plug. Thankfully the glow plugs are cheap.
1 - 2 of 2 Posts
