1 - 15 of 15 Posts
I previously posted this in the drive line section but it didn't receive any response; I'm hoping more people will have a chance to view it under general discussion.
Here is the back story. 1997 F250, 4wd, 5 spd, 136000 mi: I replaced the dual mass flywheel with a solid flywheel clutch kit form brute power part number (90636SK). The clutch I removed was in perfect shape — almost brand new — only the Dual mass flywheel was getting week. Main seal was not leaking, so I didn't replace it; no oil on the old clutch either. driving it Immediately after the replacement there is a shudder in the clutch when starting from a stop, and a hard down shift. This was not a problem with the original clutch. I contacted the supplier and Brute Power who denied that the problem was in their parts, excusing it as worn spring shackles, motor mounts, oil or grease on the mating surfaces — basically anything except their kit.
I have been driving it in this condition for about a month now and it seems to be getting worse. In the mean time I notice that the truck does not shake side to side , which would be indicative of spring shackles and or motor mounts, but lurches forward as the clutch grabs and slips, until I completely release the clutch pedal. This tells me that there is a high spot on one of the components in this kit.
While trying to get the supplier to honor the warranty, they deny there is anything wrong with the kit. The only way they will do anything, is if I remove the clutch and send it in so the manufacturer can inspect it, and if they determine it is a warranty issue then they will send a replacement. This leaves me vulnerable to them not honoring their warranty once the parts are out of my hands. This policy also leaves me without a truck until they make a decision; of coarse, the supplier offered to let me purchase another clutch kit and swap out the old one, before I send it in for warranty review. This sounds like one good kit for the price of two. If I have to buy another kit It will be from someone else not the same supplier.
My questions are:
Is there anything I should look for externally from the clutch that will cause these symptoms?
And, Has anybody else had experience using a Brute Powers clutch kit?
If I purchase another kit, what is a safe, affordable, stock horsepower option?
Thanks in advance for your input,
Andrew
The Napa clutches are pretty good ( I think they are Sachs or Luk), but Luk it a great one. My suggestion is to buy more clutch than you think you will need as if you add more power later your clutch will already be done.
Did you break in the clutch? What about checking your pedal rod bushing on your clutch?
That's good to know because Napa is the only parts store around. And, can you describe a clutch break in?
what kind of clutch lining did you get? if it is ceramic or kevlar they will grab a lot harder and feel jerky. also were the clutch components super clean prior to install? they come with a covering of oil on them that needs to be cleaned off.
other than that i can only suggest going with a quality clutch that has a good reputation and thanks for the heads up about the poor customer service
glovemeister,
I didn't do anything special, just normal driving. I've maybe put 300 or so miles on it, and it doesn't seem to be improving, and if anything it is getting worse.
Desertdeer,
I don't know what the lining is. It’s not specified and I haven't been able to verify anything with a search; I’ll call them and ask. The kit came complete with the flywheel and I had a qualified trusted mechanic install it. I asked about oil on the surface first off; he assured me that all the surfaces are clean of grease and oil; he wouldn't have me pursue a warranty claim if he thought there was some other problem.
still has dmf right??? Sounds like the dmv to me.
Always buy components from a good manufacturer.. never even heard of brute.
Yes, I know! I know!:banghead:
Brute power is sold by Perfection clutch. If what you mean by dmf is dual mass flywheel, then no, the kit is a conversion to a solid flywheel; it came complete with flywheel, pressure plate, clutch plate, cover, and throw-out bearing.
I'm probably going to remove this kit and send it back for a refund and apply for a labor claim.
Perfection clutch?? Who the hell is that????
It sounds like a poorly designed kit to me to be honest. I'd grab a better kit and better clutch to be honest... I wouldn't even mess around trying to "fix" whats wrong besides doing what I just said and removing it all.
Brute Force has been around for years. It sounds like either it is just a grabby clutch(depends on material), or the pressure plate is screwed
Jensen has been around for years, and so has Superchips... and I still wouldn't run either of them ;)
1 - 15 of 15 Posts
