1 - 8 of 8 Posts
2009 f-350 6.4 clutch fan always on loud fan noise. I can turn the fan by hand, fan is not lock up. I disconnected the wire harness for the fan and I started it, the fan stay on about 5-10 second after no fan noise. I know its not the fan clutch it’s ok. I have a code P0337 crankshaft position sensor a circuit low input I erased three time but code P0337 keep reading out. Can anyone help! Thanks you!
Use your monitor (preferably ForScan) to look at the temp sensors (engine and transmission) -- when cold, they need to be not more than a couple degrees apart
That code can be set when the cranking voltage drops too low -- need to check while cranking, you should not see below 10 volts
With the fan disconnected, do you still get the P0337 code?
I do the scanning. I didn’t scan with fan disconnected I’ll try that. I’ll keep you posted Thank u!
I disconnected the fan still got P0337. I can’t do engine temp. And trans. Temp can’t scan it does support it I have cheap tool.
Do a search on my recent posts and find the ForScan info -- that will get you a good tool for not much money
Maybe your search foo is weak ;) , but here is the info:
I suggest downloading ForScan and using the OBDLink MX+ or the BAFX adapter for troubleshooting
Torque Pro would be good for everyday use with an old phone or tablet -- can be mounted on the dash
Scan Gauge is small and simple -- can be mounted in front of the instrument cluster
there are other monitor solutions, but the price goes higher
ForScan is a simple download for PC, you can get it in just a few minutes -- the "lite" version is available on the app stores for your device.
There is a "demo" in the app options, so you can use the app without being connected, to get familiar with the screens
The BAFX adapter is the least expensive and a reliable adapter -- the MX+ is smaller, faster and more features
The PC version is the most powerful and does the "click test" and other tests
you do not need the license for troubleshooting
Discussion Starter · #8 ·
Hey ur right haha🙂 thanks again for the links have a nice👍🤙😎🇺🇸
1 - 8 of 8 Posts
