I just picked up a 97 F-350. The clutch fan seems to always be engaged. Is this normal in the OBS, I have an 04 6.0 and have drove many super duty with 7.3's and the fan always disengages. Is it normal in these trucks or is something wrong?:icon_ford:
No that doesn't sound normal. They will usually spin hard at first start up with a cold engine and then disengage after a couple of minutes until the engine gets up to temp.
What makes you think the clutch is engaged? Are you talking about a full lock-up of the clutch, or partial?
My fan clutch rarely locks up, and never during typical cruising. I've got to be loaded down pretty well and pulling a grade. I like to call it my afterburner, as I can hear it in the cab even overtop of the engine whirling at 2800rpm.
How are your operating temps looking? IIRC correctly, a properly functioning clutch will lock when the air reaching it approaches 205* (air being passed through the radiator). As with any thermal viscous coupling, lockup will be gradual up to this point.
Let me know if you need a procedure other than FoMoCo's for testing the clutch.
the one in my dads super duty got stuck on (locked in fully at all times) and we replaced it now it wokrs like normal
