Hey guys so I’ve got a 2000 dually 6 speed 2wd, I’m getting a pretty loud clunk that’s got me worried. It happens Under heavy acceleration, deceleration using engine braking when the clutch grabs, when I let the clutch out too quickly from a dead stop and even when I made a slightly aggressive right hand turn last night. I have changed all fluids, new u joints and greased the slip yoke with some general purpose grease I had laying around. Any ideas?
Check sway bar end links
check body mounts
check track bar bushings and upper track bar mount to frame
check drag link and steering bars to each side
check carrier bearing if you have a two piece rear drive line
When you greased driveline did you remove and then make sure the u joints are still lined up when re assembled?
I had the clunk before I did the u joints and afterwards it went away for about 2 weeks and now it’s back, everything seems to be lined up
What did you use for U joints?
Who installed them?
Did you loose the needles out of one of the caps?
Did one of the caps get broken/cracked?
Did you hammer them in or press them in?
