1 - 20 of 23 Posts
I've been searching for the clear lenses to replace the amber parking light lenses and clear for the headlights... anyone know where i can find ones for my 97 obs? everywhere I look only has them for the f 150's or the superduty
If i'm not mistaken, OBS F150 and F250, F350's all have the same headlight/turn signal lenses, so the f150 ones will work on your truck.
I could be wrong tho.
ya that's what im not sure of... i'm also looking for the LED taillights... but i don't want that euro crap.. i just want the same red lenses with the led bulb set up
I have crystal clear lenses up front and got em off ebay, look awsome. And I bought all LED bulbs for the truck too it makes it look like a new truck. O yeh I got led fog lights too there bright
F150's and OSB's are all the same front sheetmetal parts. Don't forget to add a Hella Harness and some 80/100w 4k Kelvin bulbs!
Cary
Thats what i thought!:thumb:
Just wasn't quite confident to say for sure:doh:
try ebay thats where i just got mine they had all different years the ones were for 99
Discussion Starter · #8 ·
thanks for the info!
92-96 F150 is the smae as your obs 250 350 450
Big K showed me this place
3157 Tail Light Brake Light Turn Signal LED Bulbs
they got everything just go down and you need 3157 series they got every configuration for led bulbs, and trees
and btw you dont need an upgraded harness for new headlight bulbs the stockers wont burn up and supply more then enough.
The upgraded harness is so you can run full voltage to the bulbs and also run 80/100w. Can't do that running the stock wires or the stock switch. The harness has new relays and heaver wires so your dash switch no longer has the full amperage running thu it.
Cary
Discussion Starter · #13 ·
sweet. thanks for the info!
oh ok im just sayin your stock harness wont melt with the 80/100w
I got mine from procarparts.com. They seem to be working pretty good so far.
you will have to get the clear parking lenses off ebay or a buddy. they are illegal to run on the streets. that is what i was told from vendors that used to sell them.
LMC TRUCKS no longer sells the clear parking lights for the ford obs as they are illegal to run on the streets. dont know why that is what i was told. just passin on the info. you can find them on ebay though. yes they look great.
get them off ebay about $120 per set shipped for everything head lights corners, and turn lights i put all orange bulbs in and they look supa coo
how do you get your old ones off....i have tried and i am afraid that i will break somethin
1 - 20 of 23 Posts
