1 - 1 of 1 Posts
· Registered
Quick Tip for a thorough clean on your EBP sensor tubing going to the intake manifold—- when you are recycling the tubing....
Credit to my wife: Take ear plugs— plug up one end, spray ‘Purple Clean’ down the tube until flooded 100%—- saturate the other plug with purple clean, then plug up the other end of the pipe, leave over night.... And BAM—- drop the part in boiling water for 1hr... Spray Carb cleaner through it to confirm all loose carbon is gone, and a wire hanger to double check the “ALL CLEAR”...
770152
1 - 1 of 1 Posts
