1 - 10 of 10 Posts
Yep...its me again. Got a quickie question. I now know that with the old chip thay was in the truck, I was constantly getting the ses light and the dreaded P1211 code, which I understand is usually the norm for chips to do...Question is...is there a way to bypass or somehow prevent this condition? Without spending a fortune (which I don't have anyway) Any assist with this would be helpful. Thanks
Howard.
duct tape & zip ties
Howard.
If I remember correctly P1211 is the code for the map sensor correct.
If so just get an air pressure regulator and a couple 1/4 inch hose connectors. Set the Air Pressure Regulator for 20psi. Then put it in the map line going to the map sensor. This will prevent your SES light from coming on.
If you don't know the Map Sensor is located by the A/C condensor on the passenger side of the engine compartment by the firewall. It has a wiring harness and rubber hose going to it. You can either cut the hose and place the regulator in line like that or you can get a short piece of hose and put in like that. Also most regulators have an arrow on them pointing in the direction of air flow. Make sure you have the arrow pointing towards the map sensor so the boost will flow to the map sensor. But it will be regulated to not go over 20 psi.
This all costs about 20 bucks at the local hardware store.
I also recommend that if you do not have gauges yet that you get them. Especially Pyrometer and boost and tranny temp. This is so you can prevent damage from occuring to your engine from over boost, or High EGT's.
nope...the P1211 is the "IRP above ar below desired" It seems, and Jody at DP agrees, this is pretty standard and norm for chipped engines..something about the HPOP not being able to keep up. Also...I have guages, and the boost seems to always be low...the absolute may I've EVER seen, and that was with the old chip, was about 15..and that was once!, under WOT climbing a steep grade.
P1211 is ICP above or below desired level If i remember the overboost code is P1249
thanks Scott...thats kinda what Jody said...makes me long for the old days of duct tape and bailing wire...all ya needed to keep your rig in tip top running shape..LOL. Its just that any time that light comes on..the ol "pucker factor" shoots through the roof! BTW Scott..I did finally sell my smaller truck..took a total beating on it big time but couldn't afford another month's insurance. Still need to have ya take a look at this beastie and tell me what needs fixed/replaced/exploded/run over a cliff/polished/caressed/kissed an/or scheduled for therapy. This engine mis is driving me nuts..and it ONLY started doing it AFTER these jerk-offs at Allegheny Ford replaced the PCM. Anywho...I'm starting to look for a load going down your direction so I may be giving you a call at a moments notice letting ya know I'm on my way...'course, if you're fishing...I completely understand..LOL
howard if you run a chip it will set that code , no way around it
Thats funny my ts-6 pos chip never sets that code off, but it did set off the map sensor code. That is why I put in my homemade mapfooler.
i have the same problems with my chip. it does it on the 75 and 100 hp setting. sucks. gonna put in a 17 degree hpop soon. maybe that will stop my problem until i can afford duad hpop's. i feel u on the pucker factor though!!!
1 - 10 of 10 Posts
