I have an early 99 f-350 which i bought rolled over. I put another cab on it and just got it running. I put bigger injectors in it and a bigger turbo. The truck will run fine until i plug the chip in then it shuts off just like you turned the key off. I tried two different chips and they both do the same. I double checked the terminals to make sure i had it cleaned up good where the chip plugs in. they are clean. Any ideas would be appreciated.
