Ok, I just had an injector go bad. The truck was missing really bad and had now power and the check engine light was not on.
Replaced the injector with a rebuilt on and new o-rings. Truck runs fine and has all its power back.
Check engine light turns on and off now. At idle, it turns on and then turns off without even touching the pedel. Driving it around, it is always on when you are on the gas, even partial throttle, and when you let off the pedel it turns off.
Truck only has 130k on it, 2002 powerstroke. Mods: 4in turbo back, dp tuner and intake.
I took it to two different places to get scanned and nothing came up. They were the cheap scanners from like autozone. I read that those will not pull codes. I do not want to take it back to the dealer to pay another $100 for a scan. If anyone can help, that would be great!!!!!!!!!!!!!!!!
duct tape & zip ties
You will need to get the codes pulled from the pcm in order for us to help you.
But if your truck is running great and the fact that your cel light is coming on and off I believe you are getting the typical codes because of the tuner.
