My 2000 f250 2wd is sitting a little low for my taste any ideas for some budget lift? I am looking to clear 19.5" or 22.5" rims
Unfortuneately, it seems going with bigger rims on a 2x, airbags are the way. You could, however, find someone to fabricate you some blocks for the rear. Problem is: you'd need a budget method to lift the front....:doh:
OperationSmile.org
cheap and lift should never go together. You can clear 22.5s on a stock truck as long as your tire size is proper. You would have to run some low pro tires.
I agree with "cheap & lift should never go together."! I also agree with proper tire sizes. Save up some more money, brother!
