Maybe I should have given you a link to my video. But, first, let me unpack what you wrote.
QUOTE
2005 F250 6.0, 215K miles, owned since new. All maintenance was performed mostly on time, and all the things that can go wrong did! Currently on an extended RV trip. The short side of the issue is the Batt light is intermittent.
Truck running, a check with a multimeter with the light on or off shows 13.8 volts at batteries.
Later, the Batt light was on more than off. Checked batteries-12.0 volts after long drive time.
There are two things the "battery" (Should have been a charging light) light is telling you when it is on.
- The alternator is not charging (light off).
- The alternator diodes are not in good condition and introducing AC into your system. You can have suitable voltage with bad diodes.
AutoZone tested the batteries, which measured good to low, so we needed to charge the batteries before testing the alternator. Charged overnight; test showed the internal alternator regulator failed.
The auto parts stores are not infallible and sometimes do not do a good job at all.
New, not rebuilt, alternator installed; charged batteries, but the light is on. After GPs are off, the alternator output is 0.
Test new alternator at AutoZone; internal regulator failed same as old alt. Batteries 90% & 100%.
Test old alternator seven times: All pass - I don’t think it is the alt.
Again, auto parts stores analysis can be questionable. And auto parts store alternators can be bad out of the box.
Miles later, batteries are low; charge batteries overnight.
Whatever alternator is on the truck ain't working.
Start driving 10 miles .... no Batt light. Test volts at batteries with multimeter truck running-14.3 volts.
Working.
Go to turn the truck off; the Batt light is on.
Not working.
Test again at batteries 12.5 volts.
It should be around 13.5v if the alternator is working and the truck just turned off.
Ohm test between Alt red wire and battery-good.
Engine running and warm; no output from alt.
Engine off-key on; no voltage on green wire.
Cluster/connector/wiring.
Did not test the other alternator wire.
The other wire is the 'sense' wire; it then is the reference that tells the alternator how much to output.
Checked fuse 45; good.
I do not see an issue with the oil temp wire.
If I understand correctly, when the engine is cold and the GPs on, there is no power to the alternator. After the engine is warm, the GP power is off to alt at the green wire.
The signaling Power to turn on the alternator is on anytime the key is on.
Is this correct? Is the voltage to alt controlled by the GPM?
NO.
If so, which wire can I test out of the GPM to see if it provides voltage to the alternator?
If not, where does the green wire get its voltage?
Per the diagram, the light green/red stripe wire is the grounding side of the 'battery/charging' lamp. When the key is turned on, positive goes through the fuse 45 to the cluster and then the one side of the 'battery/charging' lamp. The other side of the lamp is the light green/red stripe wire going to the alternator. When the alternator is not producing electricity, it acts as a ground for the lamp, so it's on. When the alternator is producing, there is an equal voltage on both sides of the light, so it does not glow; no ground.
Side Note - If a diode is bad, the voltage will not be rectified close to battery voltage; it can be up to -1 to +1, for example. So the voltage swings at the alternator are not equal to the voltage at the batteries (key switch), and the lamp can come on.
Any suggestions are appreciated. Thank you!
End QUOTE
While you might have a cluster issue, it's more likely you may have a connector issue at the alternator. If it is not fully engaged, or the wiring at or an inch or two away from the connector might be frayed, this can cause battery light fluctuations. There is a tab on the connector that should lock firmly into the alternator's body.
You can buy connectors with pigtails at the auto parts store to replace them if needed. I had to on mine. In the field, you would have to use the crimp-on butt connectors to spice it correctly, ensuring the wires go to the correct side of the connector. The replacements are not correctly color coded.
The one thing I'm worried about in your description is the voltage of the light green/red stripe wire only stayed on for a short time. That might be an issue with the cluster or an indication of the wires frayed. Note - I don't care for test lights; I don't own one. I use multimeters and check for voltage or continuity.
The Ford Service Procedures have a step-by-step process for checking all this.
You can use the 110a alternator, a 140a, or up to the 300's. Most prefer something at least in the 140a range, and both the 110a and 140a alternators perform better in this vehicle with a smaller pully to increase the idle speed output. But changing to a 140a or other alternators will not solve this unless you have the unfortunate situation of two bad alternators.
My video on the subject.
That Darn Battery Light
