1 - 12 of 12 Posts
Changed pedestal.....check engine light on??
I just changed out the stock pedestal for a Garrett non EBV one and now my check engine light is on.
There was a sensor on the stock pedestal, there is not one on the new pedastal.
Is there a fix for this?
Can I just brdge the wires on the connector?
I need to get the check engine light off becuse I live in Komifornia and I need to get the truck smogged soon.
The truck is an 02 7.3
take the bulb out problem solved :D
Not sure really what to tell ya. I unplugged mine way before I modded mine to not have it and the check engine light never came on. Im sure somebody will chime in soon:thumb:
O.I.F. Combat Vet 11B
pull the code and see what you come up with. you might have just left something unplugged.
lost in space
hmmm, but that fix is for OBS trucks...any difference?!?
Supporting Vendor
Uh. No. You must have a CA emissions truck if the EBPV solenoid being disconnected causes the CEL to illuminate.
Shorting the wires will cause just that, a short. This can damage the PCM over time.
Take the EBPV solenoid out of the old pedestal, plug it in, and drop it in the engine valley. That will work for a little while until the diagnostic strategy determines that the EBPV is not closing during testing.
Yes, it is a CA truck.
Does anyone know how to DIY a plug?
I really hate to spend $40 on something that will probably cost me under $5 to throw together myself if I had a "how to".
oops yeah i rushed and meant to post the one for the 99-03... but ya u get the idea.. ha.
Discussion Starter #12
Someone must have a DIY mod for this...:dunno:
I can't be the only one that has changed out the stock pedestal.
1 - 12 of 12 Posts
