1 - 2 of 2 Posts
how can I tell when a centrifuge has filtered out enough of the particles to run the wvo through my engine? I have a vegiestroke system on my truck and I am just dinishing hooking everything up.
anyway to measure the filtration level?
Send it to a lab. That's the only way to be sure. How many passes did you make through the CF? If you have a 55 gallon drum, and a 1 gallon per minute CF System, you would have to run it between 4 and 5 hours to get down to the 1 micron range. Or you can clean your rotor, and run the system for another 30 min. to an hour, and see how much goop still gets pulled out.
1 - 2 of 2 Posts
