Tore into it myself and found the two bolts inside the center console on the bottom, i removed them and played around with trying to lift the console under LIGHT pressure(don't wanna break anything) and the rear of the console had some play in it but the front of the console felt like it may have still been bolted down. I searched around on here and got confused with the bolts near the cup holders and the arm rest of the console and possibly having to remove the front seats.
I just got a weather tech floor liner and im pretty sure it tucks in underneath the console because it doesnt fit right in the console area.
All i need to do is lift the front of the console a few inches to slide the floor liner in underneath.
Do i need to remove the front seats?
Thanks for the help.
There are 2 more bolts under the cupholders. Those come off with two screw at the top of the cupholders, under the latch, and then take those two bolts off. You'll be able to lift off the center console but will still have the main brackets. You'll have to remove the seats to get those out.
I may be wrong about the two bolts on the cupholder/front panel....it shows to just pull off....mine is a custom built one so I can't go look at how I took it apart....
Subscribed, removing mine this weekend most likely
