1 - 5 of 5 Posts
I have been running the SCT LIvewire since the truck had 5000 miles on it. I now have 24000 on it. I straight piped it 5000 miles ago and got 3 codes today.
P0284 Cylinder 8 Contribution/Balance
P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient Detected
P1000 On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
I figure the last is a result of the first two....the truck runs fine but it is louder than usual like the EGR is stuck in the open or closed position. Any thoughts on this would be helpful!:confused::confused:
Thanks in advance!
yep that was 5000 miles ago!
If you did remove the DPF do you have the DPF delete tune installed on the LiveWire?
Yes to all the above....5000 miles ago and I have been running the extreme tune the entire time. I cleared the code and I will see what happens tomorrow.
What would cause the EGR flow to be limited????
1 - 5 of 5 Posts
