I just got my 04 F250 Diesel back from the dealer after shelling out $5100 for head gaskets. The dealer also replaced the batteries while it was there. Now my CD player won't work. I called the dealer and he said it's nothing that they did and I'd have to bring it in. Does anybody know if this is an easy fix problem? Is the radio tied into the engine management like on a VW that could have been messed up when they did my gaskets? It was working fine BEFORE I took it to the dealer. It has 6 CDs in it but says NO CD when I try to play them. When I try to LOAD it says CD ERROR and does nothing when I try to EJECT. WTF. I'd rather not spend more money on a new CD player. Any of you techs out there know something the dealer may have done that may have caused this. The head gaskets blew within about three months of getting the coolant system flushed on the truck. It's turning into a series of unfortunate (for me) and expensive coincidences with this dealer.
Try this...
When trying to eject a CD take a thin knife blade and see if you can lightly pull forward on the top of the CD to get it to eject.
I had a problem similar to your and once I got the first CD out, was able to eject and reload all 6 and it worked fine after that.
You should be able to see the front edge of the CD by looking in the slot, then slide the blade in on to of the cd, press lightly downward while slowly sliding the knife/cd out towards you.
Also this might be of interest:
Speaker Walk-Around Test:
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic
mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
1. To enter the speaker walk-around test, simultaneously press and hold the
audio unit preset buttons 3 and 6 for approximately 3 seconds, then release.
2. The speaker walk-around test applies sound to each speaker for about 1.5
seconds. Each speaker is tested and displayed on the audio unit in the
following sequence: RF, LF, LR, RR.
Audio Unit Self-Diagnostic Mode:
• NOTE: Always document and clear DTCs and carry out the audio unit ondemand
self-test again.
1. To enter the following tests, press the desired preset button while in the
speaker walk-around test or while in the audio unit self-diagnostic mode.
2. To exit the audio unit self-diagnostic mode, turn the key or the audio unit
to OFF.
3. The audio unit self-diagnostic mode has 5 tests available:
• Preset Button 1 = Audio internal/external SELF TEST. This test is an ondemand
self-test. If SELF FAIL is displayed, press TUNE > to scroll through
the DTCs stored. Refer to the Audio Unit DTC Index. If the system is OK,
SELF PASS will be displayed.
• Preset Button 2 = View/Clear continuous DTCs. NO DTCS is displayed if
no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view
the DTCs retrieved. Refer to the Audio Unit Diagnostic Trouble Code (DTC)
Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be
displayed.
• Preset Button 3 = SIGNAL TEST. This test measures the average
strength at the current tuner setting. ** Perfect for testing antenna types
and position changes. **
• Preset Button 4 = Software level query. This test queries each audio
system controller for its software configuration level. SOFT LEVELS will be
displayed upon completion of the query. Press TUNE > to scroll view the
software configuration version level.
• Preset Button 5 = DISPLAY TEST. This test will light all the audio unit
display segments for 5 seconds. When the test is complete, DISPLAY TEST is
displayed on the bezel.
5. To exit the self-diagnostic mode, press the power button on the audio
unit or turn the key to the OFF position.
Audio Unit DTC Index:
DTC - Description - Action
B1317 - Battery Voltage High - CHECK the charging system.
B1318 - Battery Voltage Low - CHECK the charging system.
B1342 - ECU Is Faulted - CLEAR the DTC. CARRY OUT the self-test. If DTC
B1342 is retrieved again, REMOVE the audio unit and SEND it to an
authorized audio system repair facility.
B2406 - Audio Disc CD Player Internal Fault - CLEAR the DTC. CARRY OUT
B2406 is retrieved again, REMOVE the audio unit and SEND it to an
B2477 - ECU Configuration Failure - CLEAR the DTC. CARRY OUT the selftest.
If DTC B2477 is retrieved again, REMOVE the audio unit and SEND it to
an authorized audio system repair facility. REFER to Section 415-01 . TEST
the system for normal operation.
B2924 Audio Button Stuck INSPECT the audio unit for a stuck button and
REPAIR the concern, if possible. CLEAR the DTC. CARRY OUT the self-test. If
DTC B2924 is retrieved again, REMOVE the audio unit and SEND it to an
B2965 - Audio System Speaker Circuit Fault - See Ford Factory Service
Manual for troubleshooting steps.
Tried prying the CD out, nothing. Did the system test and getting the B2477, AWWWW now I guess I have to go buy an aftermarket headunit. And to top it off my Metallica Hardwired CD's are stuck in there ! Dam thing!!
Those 6 CD player are junk. Good news is you can take it apart and get your cd's back.
If you look closely at the unit when you take it apart. There maybe a little gear that has fell of the motor. If you push it back on it will most likely work again.
