what size heater core hose line do you need and what do i use to plug the port on the intake tube?
If you are just routing the tube back and down under the truck, you can use a piece of 4" exhaust pipe in the place of the black plastic piece in the intake. I did that for 3 years till I bought the NC Hornet CCV set up which uses that black plastic piece .
Electrical Ogre
3/4" heater hose for the CCV. You can buy 3/4" heater hose "bypass caps" at NAPA to cap the intake port.
