O.I.F. Combat Vet 11B
well, I did this mod a couple weeks ago and so far it is working like a charm.. my only question would be is I just checked it few minuets ago and had about 3 tablespoons of oil in there. should I be concerned with it blowing that much?
Did you get the kit from Stealth Automotive? (If so, how was the install - fairly easy?)
I'm looking at getting that kit here pretty soon.
Sorry I couldn't help with your question.......
Powerstroke Junkie
It would help if we knew how you did your ccv mod. There are right ways and there are not so right ways. I am the one who makes the CCV mod for stealth. If you have any questions PM me. If you used my kit 3 tablespoons is a lot for just installing. It usually takes 7-10K to fully saturate the filter material and for the oil to collect in the bottom of the canister. Check and make sure you have the supply line going high up over the brake booster. This is a very critical step, if it isn't performed you will collect a lot of opil real fast in the canister. If you have any ? feel free to PM me.
Stealth Automotive Inc - Exception
NCH
