Carrier Bearing Drop? attn DCSpecial
Does anyone know how much drop I need in a 11" lift for my carrier bearing drop? Only have about 2" spacer on there now and getting a vibration constantly.
Is there a formula to figure it out? Thought I saw one on here one time.
Discussion Starter #2
Nevermind. The rubber inside the support bearing is shot. Can push the driveshaft all the way up, Its not keeping it in a center position. Now rockauto, shows a 35mm n a 40mm. Which one do i need?
pull it off and take with you. mine was the bigger of the 2. the bearing may have gone bad due to drive angle. i would check with DCspecial.
Thanks, I dont know if the bearing is shot just all the rubber around it is falling apart
