1 - 20 of 21 Posts
Hey guys,
I'll be picking up a carli 4.5 setup here in the coming months. Working with a budget right now as well so I'm stuck between a rock and a hard place.
I am either going to get the 4.5 commuter with the full progressive springs for the rear or I'll just be picking up a pintop system.
I wanted to know which setup you would go with an why. I don't do any high speed off roading. If anything its crawling through some muddy areas to get to the hunting cabin etc.
I know the pintop is the best and will give me the best ride but I can't do that with the full progressive springs in the rear. Eventually I would like the full setup with air bags but its going to have to be a building game from here so where would you start?
Several thoughts in my mind:
1) Springs will last longer than shocks over the same driven amount miles.
2) Some people report shocks needing rebuilds at 50k or so...just food for thought. What is their warranty for the shocks?? How much is a rebuild?
3) Buying better shocks on OEM rear springs now may give you the better ride with a small load in the bed versus an unloaded truck with the full spring pack.....maybe....maybe not. Do you need the OEM load capacity?
4) Hey...it's only money....spend once, cry once.
What size tires/wheels are you going to use???
I'd buy the rear spring pack as an upgrade later on. The tire/wheel setup will give you TONS of ride quality with the pintop shocks.
Vendor
Hey guys,
I don't recommend the full leaves with the Commuter shocks as they were tuned for the add a packs specifically. When combined with the softer Deavers the truck can be a bit too soft and bouncy in the rear. I have customers that go that route sometimes if they plan to upgrade shocks in the near future but not too long as the rear Commuter shocks will get overwhelmed pretty quick.
Adding the Full Leaves down the road can also get costly due to the added shipping costs (we ship the leafs for free when purchased with the kit) and the extra work of doing the rear twice.
Based on your planned use you will probably be fine with the Backcountry Kit and full leafs. The Backcountry rides a bit better than the Pintop on pavement but can still handle some washboard dirt road driving with ease.
I greatly appreciate this advice and most likely take it. Just curious what makes you say that the backcountry handles better on road than the pintop?
Vendor
It's all in the intended tuning of the shocks. The Backountry shocks are tuned with an emphasis on comfort for the street while being able to handle some moderate off road use. The Pintop's are tuned with more bottom out control on rough roads and you tend to give a up little small bump comfort with that. I have a 4.5 Pintop on my 17 and it rides darn good on the street but the 40's on 17's play a good role in that as well. Where it shines is on washboard and heavilly potholed roads at 50+mph.
What is your wheel and tire setup to run the 40's and how bad do they rub?
Vendor
40x13.5x17 Toyo MT's on 17x9 Racelines with 4.5" BS. With the Radius Arms, Full Leafs, Bumpers spacers, and some trimming here and there I have no rubbing:
Thanks for the perspective. I need every ounce of OEM capacity on my SRW 2019 F350 (and may need stable loads to help with that). Am I to assume that I shouldn't change out any aspect of the rear if I go with a backcountry kit?
Sent from my SM-N960U1 using Tapatalk
Discussion Starter #11
I have been told that if you do the full Deavers in the rear and air bags you get the best of both worlds. You run them empty when not towing for the best ride and then the bags when filled will give you even more towing capacity than stock.
At least that’s what I have been told
Vendor
Are you looking at the 2.5" or 4.5" Backcountry?
Just the 2.5". I'm likely to stay with 35" tires, I would just like to make the ride a bit more comfortable on dirt roads, forest roads and BLM trails while full-timing in my truck camper.
They make a heavy duty full spring pack replacement according to the website. Never read any reviews though. I think you are pretty limited on airbags if you are only going 2.5” lift.
Vendor
You are correct!
Vendor
Ok,
What does you camper weigh and is it in the truck 100% of the time? That will help determine the best overall setup in the rear.
Vendor
Yup,
The HD packs are for trucks that are loaded 100% of the time with at least 1000 lbs in the bed. Pretty much for guys with slide in campers or welding rigs that never remove them. For trucks that see lighter loads and spend sometime empty, your best bet is still the standard full leafs and air bags. Carli's bags only work on trucks with the 4.5" kits due to the limited room under the truck at lower light height for their long travel bags.
We've set up lots of 2.5"Carli trucks with other bag kits and out best result has been a combo of the 2wd Air Lift bags, a set of Daystar cradles, along with a few extra holes drilled.
I've run that on my 11 with a 2.5" Carli system and full leafs for 5 years now:
Yup,
Do you sell this airbag setup?
Ok,
I'm still in the process of purchasing a camper. However, the most likely model of camper I'll be buying is about #3200 wet weight with another 600# in the cab (including me). That makes me right at or slightly over my stickered payload, but the truck can obviously handle significantly more than the door sticker.
The idea is that camper will stay on the truck roughly 70% of the time.
Vendor
1 - 20 of 21 Posts
