1 - 2 of 2 Posts
2008 6.4 F350
I have DPF delete and sct tune.
Greetings thanks in advance for all your help
I have been dealing with this all day. Talked to SCT they re flashed my unit a few times. Error messages kept coming up.
Heres what happened I warmed up my truck then went to leave to go to work, put it in reverse and it immediately shut down.
I tried the bypass start method and it will crank but not start. Not throwing any codes. I have a scanner that can check the systems and it is not communicating with the TCM. The shift light is also flickering. I am at a loss. Was on the phone with SCT for hours no dice.
1 - 2 of 2 Posts
