1 - 8 of 8 Posts
i have an 03 ford f250 with the 6.0 I'm having trouble nailing down some problems with it. If i dont drive it everyday it doesnt want to start. It cranks good but it stutters and then finally goes. I thought it was glow plugs but they all test good. I pulled the egr valve and it s working, so i cleaned it and put it back in. I've changed filters, checked my high pressure oil pump and ran diagnostics on the injectors. The only other thing i can think of is the injector harness. This is my first diesel and i've only had it about a year. just a little frustrated.
what is your FICM voltage it can also be the dummy plugs on the injector rails and check the ICP
the FICM is the module on the left valve cover? and ICP not sure where it is and i had no idea that there was dummy plugs on the injector rail.
I highly recomend follow this link DTS Articles - Coffee Table Books download the 2003 coffe table book commonly called the 6.0 bible. An exellent resource for a 6.0 owner.
NOTE: Hope ya have cable it's a 11mb download.
Save it to your hardrive for future reference.
thank you everyone that helped me i am workin on all your suggestions
Load test the batteries prior to testing ficm. I think your batteries are crap, and it's probably killing your ficm. Get a monitor on that truck, I use edge insight cts.
1 - 8 of 8 Posts
