1 - 7 of 7 Posts
my turbo went out of my 01 psd and the junk yard said they have one without a exhaust valve and my truck has a exhaust valve, what is the difference in the two? if its just the exhaust housing can i switch the housings from my turbo? what would happen if i just use the non valve turbo?
Yes you can use one without the exhaust valve. Its just a housing swap that takes no time!
Nothing really. I unhooked and loctite'd mine, and alot of people gut theirs. It's just a warm up valve for cold weather. It doesn't really serve an important purpose. And to swap those housings... believe me, penetrating oil will be your friend.
Swap them. It is better withour an ebpv
Its kinda like an appendix for your truck!
i wanted to keep it on because we have cold winters in michigan and it is a plow truck so it needs all the help it can get warming up, even with the valve it still takes a half hour in the winter to warm up.
Well like i said it is very easy to just swap the housings. Will take every bit of 15 minutes!
1 - 7 of 7 Posts
