1 - 12 of 12 Posts
is it hard to install one of these in the 6.0 this code keeps popping up ever now and then and i see there are only a 26$ part? anyone ever done one and know where its located with a possible pic?
Discussion Starter · #2 ·
:bump::bump::bump:
I thought that the CPS sensor was more of a problem on the 7.3's, are you sure it is failing?
i keep getting a code for it. ill clear it then it seems to always come back after awhile
i would imagine it's down by the water pump in there. yeah i guess these may be a 6.0 problem as well huh?
ive only replaced one cam sensor ina 6.0 in 5 years i remotely tought it might need , what code is it , and im thinking more of a wiring issue then the sensor itself
Discussion Starter · #9 · (Edited)
PO341
camshaft position sensor "A" circuit range/performance [bank 1 or single sensor]
i have no idea what that means
Discussion Starter · #10 ·
:bump::bump::bump::bump:
Discussion Starter · #11 ·
:bump::bump::bump::bump::bump:
according to the pinpoint test , if the engine runs and gives that code , more than likely its a wiring issue and not the sensor , check wiring from pcm to sensor , if all wiring checks good then it is possible to be the sensor
1 - 12 of 12 Posts
